Removing 940 Door Panels
Old Apr 24, 2011 | 11:03 AM
amazon2's Avatar
Default Removing 940 Door Panels
In true Volvo fashion, the door panels on my recently acquired 940 look great but how does one go about removing them as I have a power window issue. I can't see any cam-locks or an obvious starting point and we all know how easy it is to break a "little plastic tab" that we didn't know had to be released first! TD
Old Apr 24, 2011 | 03:56 PM
MasterBlaster's Avatar
If it's anything like my 740, there's a 1/4 turn plastic screw down in the door handle "well" that lets the trim around the window switches be *carefully* pried up and out, a couple of pins behind the speaker grill (which slides forward to release its grip on them), and 3 plastic clips that insert upward into the bottom edge of the door panel, grabbing 3 more pins (a couple of small screwdrivers should pry them downwards). You *might* have to remove the red marker light at the back, as it acts as another clip on some models.
Old Apr 24, 2011 | 05:11 PM
lev's Avatar
lev
The 940 has a separate clip behind the red reflector at the edge of the door-pry that off.
DNC
Sep 21, 2007 12:20 PM
daver80
May 8, 2007 04:35 PM
ko_kidd
Aug 20, 2006 10:02 PM
SpecterV70
Jun 4, 2006 03:07 PM
