is replacing front strut mt. bush/bearing DIY?
Old Mar 29, 2008 | 09:50 AM
bli745's Avatar
Default is replacing front strut mt. bush/bearing DIY?
Seems like these go every 3 years or so, not the bearing part but the rubber mount that holds top of strut.
Can it be done without needing spring compressor or other HD specialty tools?
Old Mar 30, 2008 | 03:43 AM
jonesg's Avatar
Default RE: is replacing front strut mt. bush/bearing DIY?
Mine are original, somethings wrong if they keep wearing out like that.
You will need compressors to pull the springs back.
http://www.brickboard.com/FAQ/700-90...tMountBearings
Old Mar 30, 2008 | 08:12 AM
bli745's Avatar
thanks for the great link. It all seemed to start with new struts many years ago. I was going to attempt but when I looked at gland nut it was not there the struts appeared to be a welded-in one piece unit and replacement KYBs were returned. Sent off to a local shop which cut below the 360 weld and installed new strut and the famous bearing units.
cn90
Jul 14, 2014 12:47 PM
oragex
Jan 4, 2014 01:26 PM
jefferino
Feb 7, 2009 05:32 PM
Hugh G Rection
Jul 1, 2007 02:42 PM
go2sharks
Jun 2, 2007 11:00 AM
