Replacing oil seal and centering bushing on tranny
Old Jan 24, 2019 | 07:41 PM
Dagaan's Avatar
Default Replacing oil seal and centering bushing on tranny
'86 240 DL. when I come to a stop while city driving, something rattles under the middle of the car. I think it's the drive shaft. The tranny leaks - big surprise on a 33 year old car - so the oil seal is worn and I believe there is a centering bushing at the end of the tranny. Can these be simply pulled out the back of the tranny and new ones pushed in to place?
A couple years ago I noticed some similar rattling and raised the car on jacks and ran the engine, engaging and breaking the wheels. I saw that the torque rods - two rods that stabilize the rear axle, had thick worn out bushings and replaced them. So . . . it's not that. Anything else it could be?hx.
Old Jan 25, 2019 | 05:39 AM
act1292's Avatar
There is the tailshaft bushing in the rear of the transmission that if worn causes the rear seal to fail resulting in a leak. You can replace this bushing and seal without removing the transmission. If you have a special tool, apparently you can do it without removing the tailshaft housing. Without the special tool, you would need to remove the tailshaft housing and press the bushing out.
Take a look at this link:
https://www.brickboard.com/FAQ/700-9..._Shaft_Bushing
Old Jan 26, 2019 | 10:45 AM
Dagaan's Avatar
Perfect. Thanks for the pretty exhaustive link.
Old Feb 3, 2019 | 11:51 PM
Sambar Stag's Avatar
Before changing your tailshaft bushing, I would get under the car and check the heat shields attached to the exhaust before the catalytic converter. They get loose and rattle when the car is at idle speed. Wood screws driven into the gap between the pipe and the sheet metal will tighten them up. Also check your center driveshaft bushing; they can rattle at idle also when the rubber breaks down. .
Dagaan
West
Dec 6, 2015 11:39 AM
skee b
1998-2000 model year V70
Oct 22, 2015 08:56 PM
BGoins12
May 14, 2011 10:56 AM
dwhartwell
Apr 22, 2010 08:00 PM
Kaspir
Sep 13, 2008 06:27 PM
