Same old problem is back!
Old Jan 31, 2007 | 12:07 AM
  #41
Kruspe31's Avatar
Default RE: Same old problem is back!
I have a regina coil does that mean my system is regina?
Old Jan 31, 2007 | 12:08 AM
  #42
Yes that does.
I will bet it is a square coil?
Old Jan 31, 2007 | 12:14 AM
  #43
Kruspe31's Avatar
its in the car, but i believe its round.
Old Jan 31, 2007 | 12:29 AM
  #44
Kruspe31's Avatar
No i was wrong. Its a Bosch coil and its not sqaure. I just checked its cold out
Old Jan 31, 2007 | 05:52 PM
  #45
Kruspe31's Avatar
something new just happened. I turned on the car looked at the hoses on top of the motor, everything looked fine nothing looked loose. But when I was in the car I reved up the car in park and went up to 2k then when it went down to around 1500 it started to bogg like it wanted to turn it self off. So I took my foot off the gas and it went back to 1k and it was fine. But before it never bogged when I reved up in park.
Old Jan 31, 2007 | 06:53 PM
  #46
JetTech's Avatar
Have you tried that with the MAF sensor unplugged?
Old Jan 31, 2007 | 08:54 PM
  #47
Sorry post is so long but I forget has the throttle body and idle motor been cleaned?
Old Jan 31, 2007 | 09:10 PM
  #48
Kruspe31's Avatar
I did unplugg the MAF then I restarted the car and it just died out. Haven't cleaned the throttle body. Do you know if my system is 2.4?
Old Feb 1, 2007 | 08:31 PM
  #49
Yes it should be the 2.4 system
Old Feb 5, 2007 | 09:47 PM
  #50
Kruspe31's Avatar
well I saw my mechanic again, and he replaced my coil. Now it did help for one day but the same problem is back. But I did need a coil cause that stop the car from shaking in the mornings. Now I noticed a new thing, when I have the surging problem, when I turn the car off then on, I do not hear the chassic fuel pump whine. But the car does start. Could it be the fuel pump relay?
Old Feb 5, 2007 | 10:11 PM
  #51
I doubt it. Something might be wrong with the pump itself.
Old Feb 5, 2007 | 11:37 PM
  #52
Kruspe31's Avatar
well both pumps are new. I put in a new chassis pump back in November 06 and a new in take fuel pump 3 weeks ago
Old Feb 6, 2007 | 12:04 AM
  #53
But because it is new doesn't mean it is all good.
New parts go bad to.
Old Feb 6, 2007 | 01:52 PM
  #54
Kruspe31's Avatar
maybe you are right. because when I had the new chassis pump installed it was a generic part not a named brand. And right when he started the car, the cel was on. But before that it was never on even when the old original chassis pump was dead. The old part was a bosch part made in spain. Maybe I should go back to the mechanic and ask him if he can test the new part, and if its no good I will buy a rebuilt bosch part.
Old Feb 7, 2007 | 02:40 AM
  #55
Kruspe31's Avatar
Can the main chassis pump be tested?
Old Feb 7, 2007 | 08:59 PM
  #56
Do you hear it run?
You can unplug the intank pump and see if you have fuel pressure.
Old Feb 8, 2007 | 02:52 AM
  #57
Kruspe31's Avatar
I do hear them prime when I turn on the car. I forgot to add when the mechanic changed the coil a new code came up. It was 1-1-2 and not 1-1-3. Funny thing was last thursday the code was 1-1-3, I wake up went to the shop checkd the code for the mechanic to see 1-1-3 was gone and its 1-1-2.
Old Feb 8, 2007 | 10:06 PM
  #58
HMM I would almost have to be there to check more things out.
Old Feb 8, 2007 | 10:32 PM
  #59
Kruspe31's Avatar
what does the controll moduel mean? my mechanic said it means coil?
Old Feb 8, 2007 | 10:43 PM
  #60
The control module is the engine computer.
