Same old problem is back!
Old Feb 8, 2007 | 10:51 PM
  #61
Kruspe31's Avatar
Default RE: Same old problem is back!
Yes you are correct the ECM.Well the check engine light is off, I had the mechanic remove the battery cable for 10min and its been off for the past week. if I buy a used ecm and install it could that fix my problem?
Old Feb 8, 2007 | 11:00 PM
  #62
It might but wait to see if the code comes back.
Have seen that code do that and resetting the computer made it stay away.
Old Feb 8, 2007 | 11:08 PM
  #63
Kruspe31's Avatar
I will check now to see if any codes is there
Old Feb 8, 2007 | 11:26 PM
  #64
Kruspe31's Avatar
just got back and now the dlc wont flash any codes, and the light is off. car starts fine but if the ecm is bad the car wouldnt start right?
Old Feb 9, 2007 | 12:07 AM
  #65
Sometimes it will sometimes it won't.
See if the problem stays away.
Old Feb 9, 2007 | 12:42 AM
  #66
Kruspe31's Avatar
for the past 2 days, the car drove just fine. then this afternoon started up started to drive, and started to bog. I turned it off, waited 30seconds turn it back on, but this time when i went to hear the fuel pump whine I didnt hear any, yet the car started and drove fine the rest of the day. these problems are driving me mad since the mechanic cannot pin point the problem. They checked the injectors last week, while the car was on they pulled the plugs on them and the car didnt turn off. Fuel pumps are good cause the car will always start. but when I didnt hear the main pump whine today, when the car restarted the idle for 15seconds was not good, then i put the car into drive and its all good. thanks for all your help so far Mister Tech
Old Feb 9, 2007 | 11:07 AM
  #67
JetTech's Avatar
Have you replaced the fuel pump relay and fuse? This sure sounds like a relay going bad with intermittent contact problems. Heck man, this thread is getting so long I can't remember all what you have changed...Perhaps a list in your signature or something to keep everyones memory fresh. I don't want that to sound mean either, this problem will be resolved, just hang in there. I bet your getting close to the final answer!!
Dale
Old Feb 9, 2007 | 11:08 AM
  #68
JetTech's Avatar
Oh yeah, and there have been times on my car that after I cleared the codes it would take several days before the LED would flash again. Yours will work again soon.
Old Feb 9, 2007 | 01:04 PM
  #69
Kruspe31's Avatar
I havent replaced the fuel pump relay or fuse. I have replaced so far, Main fuel pump new, New in take fuel pump, intercooler(used), Coil(Used), Cap/rotor/wires(New). The car used to shake in the morning, but the coil fixed that. I will try the relay its not an expensive fix.
Old Feb 9, 2007 | 01:35 PM
  #70
JetTech's Avatar
And try a new fuse in I think slot 7, if you look on the back of the fuse panel cover it will tell you.
Old Feb 9, 2007 | 01:59 PM
  #71
Kruspe31's Avatar
I will try that fuse since im going down to the junkyards anyway thanks
Ernie E
Mar 16, 2014 10:21 AM
donf
Jul 5, 2013 02:52 PM
ninefour850t
Jan 11, 2008 01:42 AM
kaltek
Jun 12, 2006 10:42 AM
Holly
Aug 19, 2005 03:11 AM
