speedometer having issues
Old Jul 5, 2016 | 03:32 PM
thebatpeople's Avatar
Default speedometer having issues
The speedometer seems to read ok up to about 40 mph then anything after that it reads 45 mph. There have been times when I looked and saw it reading 90 to 100 mph when I am sure I wasn't going more than 60. Sometimes it will read zero while I am going around 30 mph.
Could someone steer me in a direction that will get this fixed?
What is the most likely part that needs replaced?
How easy is the fix? Something I can handle or is a mechanic needed?
Any mechanic or a Volvo dealer mechanic.
Any pictures or drawings available because my Chilton book is seriously lacking.
Old Jul 5, 2016 | 03:45 PM
lev's Avatar
lev
The speedo capacitors are bad, need to be changed. Speedo shop can do it, general mechanic no. DIY is possible but rarely successful. 1991-2 are the worst years.
Old Jul 5, 2016 | 04:44 PM
What qualifies as a speedo shop?
Are they listed as such in the yellow pages?
Any idea of a price range for the capacitor replacement?
Old Jul 6, 2016 | 04:32 PM
lev's Avatar
lev
Speedometer repair is a specialty, general mechanic shop won't do. I'd expect to pay over $100.
Old Jul 6, 2016 | 09:01 PM
Cwazywazy's Avatar
Try to just find a replacement. It's not easy, but you can roll the odometer. My speedo was being flaky along with some other gauge issues (Not working under ~10, sometimes not working at all until I tapped the glass.) so I just got a gauge cluster out of a junkyard '92, rolled the odo by hand, and shoved it into my '86 and it works perfectly.
Old Jul 7, 2016 | 01:51 PM
lev's Avatar
lev
Problem is, 91,92 are the only interchangeable ones, and used ones are a crapshoot. I have 3 '92s, I have been all over the place with them...
Old Jul 8, 2016 | 04:59 AM
As I am looking into it more, it does seem there is a narrow replaceability. Plus I am dubious about buying a used one because it might be rotten as well. Are the capacitors cheap? I would be willing to try the repair myself if so. Is there a chance I could ruin it beyond repair? There don't seem to be any speedometer repair shops in my area so I need to look for one that does it by mail. Any suggestions here?
Old Jul 8, 2016 | 12:22 PM
lev's Avatar
lev
The capacitors are cheap but it takes micro electronic soldering skills.
Old Jul 12, 2016 | 08:00 AM
goto's Avatar
Thumbs up
Send me a private message about the speedometer.
Old Aug 14, 2016 | 03:49 PM
I was doing some checking into getting a used cluster. Thinking that I could swap the clusters. If the "new" used on is having the same issues, I would send the original out for repairs.
While searching, I saw a reference to making sure there was nothing wrong with the speed sensor(?). Where is this located and how do I check its functionality?
Old Aug 14, 2016 | 04:07 PM
lev's Avatar
lev
Speed sensor is at the rear end, at the differential, and unless the wires are damaged the sensor itself never has problems...
Old Aug 14, 2016 | 05:50 PM
So, I should locate the sensor and back track the wire checking for damage?
Old Aug 19, 2016 | 10:44 AM
goto's Avatar
Agreed.
I noticed that the wire coating on my sensor was damaged for about 2ft worth. So I cut the bad sections out and soldered/heatshrunk new sections in. Solved my bouncy speedo needle issue.
Old Aug 19, 2016 | 10:46 AM
goto's Avatar
I sent you an IM about this.
Chris
weircm81
May 10, 2008 06:09 PM
sullystull
Jan 7, 2008 01:24 AM
thejobark
Jan 30, 2007 01:30 PM
BigSection
Aug 10, 2006 12:26 AM
rejeep
Forum Issues
16
Nov 16, 2005 08:49 PM
