Speedometer jumps around/incorrect after changing rear running gear
Old Jul 4, 2018 | 10:23 PM
Caprinae's Avatar
Default Speedometer jumps around/incorrect after changing rear running gear
I swapped the rear axle in my 1990 Volvo 240 wagon with the rear axle from a 1993 Volvo 240 wagon. After that, the speedometer was incorrect and would jump around while driving, even when I replaced the gauge cluster with the one from the 93 wagon. I tried looking online but couldn't find much. Any advice? I heard it may be because the rear running gear has more teeth or whatever.
Old Jul 5, 2018 | 01:27 AM
lev's Avatar
lev
"Jump around" should not be the result of a different gearing. That would produce higher or lower speed readings. Sounds like you are having the dreaded electronic issues for which the 240s are famous.
Old Jul 5, 2018 | 07:22 AM
act1292's Avatar
The '93 tone ring in the differential has more slots than the '90 and will cause incorrect readings in the speedometer/odometer. You will need to use the '93 speedometer. As far as the needle "jumping around", make sure all electrical connections are good.
A good resource for troubleshooting speedometers can be found here:
Electronic Speedometer Notes
Old Jul 5, 2018 | 08:56 AM
Caprinae's Avatar
@act1292 I did swap the 1993 speedometer over so I will check all connections and read your link
92Sedan
May 13, 2015 02:11 PM
Schaeffy
Jul 16, 2013 02:25 PM
janeofdrama
Mar 30, 2009 10:47 PM
blue goose
Apr 16, 2008 10:38 PM
wojeepster
Oct 8, 2005 12:38 AM
