Squeeling Sounds When Braking
Old Feb 26, 2008 | 01:56 AM
Dj Eterno's Avatar
Default Squeeling Sounds When Braking
title is pretty self explanitory. however, it happens sometimes. i've recently went through a car wash that cleans under the car with a powerful jet stream of water. the sounds have began ever since this car wash. could that be the reason? hope this is a simply job i can do myself. (driving a 91 740 Turbo)
Old Feb 26, 2008 | 07:15 AM
jonesg's Avatar
Default RE: Squeeling Sounds When Braking
They sell brake lube on the checkout counter at autozone, it goes on the back side of the brake pad.
Remove wheel, use jackstands.
I remove bottom caliper bolt and merely loosen the top one, lift (rotate)the caliper up .
It usually requires a screwdriver to get it moving at first. I think they're 13mm bolts.
They can be rather tight bolts too, I use a pipe over the end of the ratchet for leverage.
http://www.brickboard.com/FAQ/700-90...tm#BrakeSqueal
Old Feb 26, 2008 | 12:31 PM
Dj Eterno's Avatar
ahh crap lol. its cold and its snowing, last thing i want to do is put my car up on a jack. eithery way help is much appreciated once again.
Old Feb 27, 2008 | 06:19 PM
jonesg's Avatar
I hear ya, I got halfway through a balljoint job on my truck and had to re-assemble it again to move it for the snowploughs , working with 3 sets of gloves due to frozen tools is no fun.
Now I have to dis-assemble it again but theres snow forecast so...
I'd gladly suffer squeeling brakes for an inspection sticker on my truck.
chris23
Mar 8, 2009 09:48 AM
Clavius
Mar 1, 2009 03:40 PM
850wagster
Nov 7, 2008 09:45 PM
i5turbo
Apr 25, 2007 02:31 PM
colgate41
Feb 3, 2007 12:56 PM
