start, run and go
Old Jul 8, 2009 | 03:06 PM
Puggs's Avatar
Default start, run and go
1990 240 DL
Might be more than one problem. Have changed plugs, wires, rotor, cap, air filter and o2 sensor.
All vacuum lines have been checked (twice).
Have to depress and/or pump the accelerator to start and keep running when cold.
When warm does not idle smooth.
Some of the time when on the road it starts to accelerate than hesitates, other times it goes till I lift my foot.
Old Jul 8, 2009 | 05:09 PM
bubba240's Avatar
I would check the LH2.4 codes:
http://www.brickboard.com/FAQ/700-90...neOBDCodes.htm
Old Jul 9, 2009 | 10:10 PM
jpravi8tor's Avatar
cold start injector issues? anyone?
Old Jul 10, 2009 | 12:12 AM
blue goose's Avatar
If it has a cold start injector it wouldn't kick in unless it was below freezing.
I would start by making sure the throttle body and idle air controller are clean. Spray them with throttle body cleaner. If they're gummed up you will likely have idle issues.
tox_slaughter
Feb 5, 2014 08:32 AM
Pelko
Sep 21, 2010 01:16 PM
Molski01
Sep 15, 2009 06:38 PM
gloria13
Apr 21, 2008 12:29 PM
