Starter problems
Old 11-15-2011 | 02:37 PM
92_940's Avatar
Default Starter problems
Wzup everybody, I own a 92 940gl redblock, Last night I went to the store to get something to drink, car started fine. Got back in it to go home, car wont start, wont click when key is turnt, all lights still cut on. Plz help...
Old 11-15-2011 | 03:43 PM
swiftjustice44's Avatar
Do the headlights dim when you turn the key to start?
Old 11-15-2011 | 04:53 PM
Wicksvolvo's Avatar
Could be alternator???
Old 11-15-2011 | 07:33 PM
92_940's Avatar
Lights may dimm a little, but not much. Battery is brand new, alternater should still be good. How can I tell if the starter or solenoid is going or gone...
Old 11-15-2011 | 10:56 PM
If the starter is drawing current, the headlights should go out or almost completely so while attempting to engage the starter. If they don't dim, the starter is not receiving current. Even if the starter is jammed, it will dim the headlamps.
Old 11-16-2011 | 09:42 PM
Burn Stains's Avatar
Originally Posted by 92_940
Last night I went to the store to get something to drink...
When a story starts like this, anything could have happened...
Is this an automatic? Could be the Neutral Safety Switch next to the gear selector.
Of course, this is a 940 we're talking about, so I'm not sure if those were as much of a problem as the 240 Safety Switches can be.
Old 11-17-2011 | 12:38 AM
92_940's Avatar
Yes its a automatic, I tried starting it in nuetral and nothing. If the solenoid goes out, will it makr a sound...
Old 11-17-2011 | 10:03 AM
lev's Avatar
lev
If the solenoid is bad, the starter should spin (make noise). you may try giving the starter a whack-it's been known to work...
Old 11-17-2011 | 11:14 PM
92_940's Avatar
Right now, I went out side and tried to start it,(it did nothing) than banged on the starter and (it clicked), banged a lil more, and it started...
Old 11-18-2011 | 07:25 AM
act1292's Avatar
Basically, the solenoid is an electro magnet that when activated causes the starter motor gear to engage with the flywheel/flex plate. When the starter gear engages, it closes contacts within the starter to activate the starter motor causing it to spin. Therefore, the starter will not spin until the solenoid has engaged.
If banging on the starter causes it to engage and work again, it sounds like your solenoid is bad. That is, assuming that you have checked the connections to the starter and made sure they are all tight and clean of corrosion.
Good luck
Old 11-20-2011 | 12:09 AM
92_940's Avatar
I replaced the starter, $114 for starter, $35 core charge, $50 installation. Im back on the road...
Old 11-21-2011 | 10:43 PM
zloetakoe's Avatar
I got a used but tested one on ebay for around 40 (risky, I know) paid about 30 for tools at Harbor freight (needed a 1/2" u-joint and the long extensions) and used about 2.5 hours of my saturday. About 2 of those hours were spent trying to get at that dang top bolt.
So it sounds like you got a pretty good deal.
xDread92x
10-09-2014 12:44 PM
Todzilla
03-12-2010 04:02 PM
ZJcory
01-15-2010 09:10 PM
Sebastiaan
06-21-2008 07:15 PM
tm_94altima
04-27-2006 10:20 PM
