Starting Ritual
Old Dec 23, 2011 | 06:58 PM
mtc28's Avatar
Default Starting Ritual
I was curious, to start my 940 non turbo I need to turn the key to on, off and then on again before starting it. Otherwise its not going to turn on. What could be causing this?
Old Dec 23, 2011 | 09:32 PM
Burn Stains's Avatar
If you just turn the key in the on position just once, and try to start it, will it just crank and crank, or will it not even try to start and just click?
Old Dec 24, 2011 | 08:24 AM
mtc28's Avatar
It will crank but sounds like it's not getting gas. I am assuming I am priming the engine by turning the key a couple of times before starting it. The guy I got the car from said thats how he did it for years.
Old Dec 25, 2011 | 08:05 PM
Joseph/TX's Avatar
I think there's a check valve located on the main fuel pump that is supposed to prevent the fuel pressure from leaking down when the engine is shut off, which has probably failed. By cycling the key a time or two you are building the fuel pressure back up where it needs to be for instant starts.
Old Dec 26, 2011 | 08:36 AM
mtc28's Avatar
Would this also be related to the hesitation issue I am having and low power?
Old Jan 1, 2012 | 02:52 PM
Joseph/TX's Avatar
Wouldn't think so. The check valve is just supposed to maintain fuel pressure for restarts; hesitation and low power are separate issues, involving the usual suspects..
watchdog
Feb 9, 2014 01:41 PM
rl92821
Feb 1, 2004 12:54 PM
watchdog
Jan 23, 2004 11:36 AM
Gene Brink
Dec 15, 2003 03:20 PM
