sticky automatic transmission shifter button
Old Aug 4, 2011 | 07:30 PM
pleiadesUnite's Avatar
Default sticky automatic transmission shifter button
Every morning and when I leave the car sitting for a couple hours I turn the car on and when I press the automatic transmission button to shift out of the neutral it takes one or more press. Any clues???
Old Aug 4, 2011 | 10:36 PM
lev's Avatar
lev
Clean the button, it's all gummed up.
Old Aug 5, 2011 | 11:01 AM
here's what it looks like inside...
its no fun getting in there.
Old Oct 22, 2012 | 12:52 AM
lentmain's Avatar
Default Hi pierse
I'm looking for a diagram for a 1988 volvo 740 auto shifter... Like a factory diagram... I'd like to order some parts for mine and I think a diagram would help a lot.
I'm having to press down on the shift button while turning the ignition key to start the car... I have to wiggle the shifter at the same time too...
I replaced the Neutral safety switch.. I'm not sure what could be creating the problem... Any help would be appreciated...
Old Oct 22, 2012 | 01:27 AM
its pretty similar.
https://lh6.googleusercontent.com/-k...612%2520PM.jpg
per your symptoms, I suspect what you will have to do is, take it apart and figure out whats worn out. my guess is, the bushings that the shift lever pivots on, like 7 and 17 in that drawing. I believe to completely disassemble it, you'll need to go under the car, and disconnect the shift rods 22 and 26 via shafts #10, then the whole shifter assembly including the cup 5/6 its in should lift out so you can further disassemble it.
Old Oct 22, 2012 | 03:31 AM
lentmain's Avatar
great... i'll try that... thanks for the diagram... now i'll be able to tell the volvo guy what i need...
thanks again...
AlanS
May 26, 2011 01:31 PM
schmuecker
May 19, 2011 06:45 PM
rpalguta
Jun 18, 2010 07:06 AM
arcas1966
Jul 25, 2009 06:01 PM
lorvar
Jun 26, 2008 10:42 PM
