Strange A/C Problem
Old Apr 20, 2012 | 09:02 PM
newmex999's Avatar
Default Strange A/C Problem
The A/C compressor on my 1993 240 takes about 20 minutes to come on. Once it comes on it runs fine and the air is cold. I checked the low side and it seems to be charged ok.
What could the issue be?
Old Apr 21, 2012 | 09:44 PM
swiftjustice44's Avatar
I believe the 93, being the only year w/R134a from the factory, has both low pressure and high pressure switches. They keep the compressor from running if detected pressures are too low or high. Might start w/ them.
Old Apr 21, 2012 | 10:45 PM
Burn Stains's Avatar
Yes, there are two pressure switches. Likely, it is just the one that is right next to the Dryer can. If my compressor does not kick on (every time) I just touch that connection and it takes off immediately. The other one is located under the car, near the outlet of the radiator hose. Might want to clean the connections, or tighten up the prongs carefully.
TedP
Feb 12, 2007 01:31 PM
kazooclown
Mar 9, 2006 10:46 PM
ludeless
Nov 19, 2005 09:12 PM
fast850r
Nov 19, 2005 10:17 AM
bill6ft6
Oct 19, 2005 12:36 AM
