strange things happen when i brake
Old Jun 29, 2010 | 11:11 AM
josseppi's Avatar
Default strange things happen when i brake
When I press the brake pedal i hear a pop sound in the dash (possibly behind the ashtray area). Also if I am at light and I press the brake pedal all the way down the car act like it is going to stall. It does this when I am in park and just idling if I press the brakes a bit nothing happens but when i put extra pressure on them i almost stalls. It has never stalled but I'm just wondering what this could be.
It is a 93 240 sedan with about 250k.
Old Jun 30, 2010 | 05:06 AM
Typhoon's Avatar
Brake booster is malfunctioning.
Regards, Andrew.
Old Jun 30, 2010 | 05:50 PM
josseppi's Avatar
do you think it is the brake booster itself or just the check valve? i looked online and the booster isn't too cheap. also is it something i should be concerned about driving? The brakes seem to work just fine as it is i just would hate to have it fail on me. It is something I will get fixed soon just how soon is the question.
Old Jul 2, 2010 | 03:47 PM
volvoguy2323's Avatar
Banned
Could be the check valve start there first cheapest and easiest. If it is a bad booster you may want to get a used one because they are spendy...safety wise I think you're ok. Good luck..
Old Jul 4, 2010 | 05:48 AM
Typhoon's Avatar
I gave you my opinion. The check valve merely stops flow in one direction, it is not the issue. You have a vacuum leak in the booster and probably caused by a torn diaphragm or defective shaft seal.
Regards, Andrew.
zachslc
Jun 14, 2010 10:38 PM
94_850turbo
Apr 19, 2007 04:22 PM
robrike
Oct 16, 2006 02:04 AM
tupapison
Jun 7, 2006 01:58 PM
S70R
Jun 3, 2006 11:28 PM
