Stripped overdrive bolt
Old Apr 5, 2022 | 08:14 AM
VolvorineMachine's Avatar
Default Stripped overdrive bolt
So I was going to put in an overdrive eliminator and when to take off the second bolt to find out the past owner had stripped it. Trying to get a clamp on that thing is near impossible. Has any one ever had this problem? How should I go about getting that bolt off.
thanks
Old Apr 5, 2022 | 10:16 AM
lev's Avatar
lev
Like any stripped bolt. Drill it, cut it, use visegrips, never a pleasant job.
Old Apr 5, 2022 | 01:10 PM
if its just the head that's stripped, you can try to find bolt extractor sockets at Harbor Freight or Lowes (they sell the Craftsmen product line now). us plenty of PB Blaster a day or so in advance, then if you have room, consider heating then chilling the bolt to help crack it loose. If you have to drill it, use a properly sized hardened bit designed for drilling into steel - it will go much faster, then tap out the hole
Nichals
Jul 10, 2016 09:41 AM
dads 740 turbo
Oct 15, 2008 12:52 AM
wingnutooa
Dec 19, 2007 09:56 PM
SpecterV70
Jul 3, 2006 01:20 AM
