strut question
Old Aug 7, 2007 | 04:15 PM
dtupac's Avatar
Default strut question
When you change the struts do you have to put the spacer in. and also does anyone know where to get replacement cant think of the name. the plate on the top side of the engine you tighten the bolts down on once aligned. I don't want to go with a strut brace just want something a little beefier.
thanks
Old Aug 7, 2007 | 09:20 PM
alabama's Avatar
Default RE: strut question
If you're talking about the strut mounts, it is not always necessary to replace them. If they are worn to the point of allowing the top of the strut to move around or if you can hear the the struts banging into the strut tower when you hit a bump, then yes, replace them. Once you have replaced the struts and/or mounts, go to a good shop and get a front end alignment.
Old Aug 7, 2007 | 11:06 PM
dtupac's Avatar
no, i'm talking about the spacers that go at the bottom between the strut and the ball joing
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
Colinruss
Oct 30, 2008 10:50 AM
go2sharks
Jun 2, 2007 11:00 AM
NYSpeedRacer
Suspension
Sep 27, 2006 08:39 PM
