Sunroof troubles
Old Sep 16, 2011 | 10:09 PM
Jakeness's Avatar
Unhappy Sunroof troubles
My sun roof on my 1995 940 opens, but does not close. Well, it does but only after a long period of playing with the switch and trying to pull it out. My dad thinks it may be jammed, I think it could be a problem with the motor. How can I fix this?
Old Sep 17, 2011 | 11:33 AM
740-TURBO's Avatar
my 740 has the same problem, Info on how to fix this would be nice
Old Sep 17, 2011 | 12:52 PM
swiftjustice44's Avatar
Guys, believe it or not, the #1 fail point is the switch itself. Not saying other, more complicated stuff doesn't fail also...just saying the switch itself can get dirty inside. Often times, hosing it with brake cleaner or contact spray will revive them. Other times they're stone dead. Be sure to remove the switch before spraying 'em.
Old Sep 18, 2011 | 07:48 PM
Jakeness's Avatar
Sounds easy enough. I'd like to try and do this tomorrow, but I'm not sure how to remove the switch without damaging it. Sorry I'm no good at this stuff, any help would be appreciated.
Old Sep 18, 2011 | 08:18 PM
The entire switch is a snap-in affair. You can pry it out at top or bottom with a small pocket screwdriver or a sturdy pic. There is a 6" pig tail on the back w/ a connector.
stejoymadandlaud
May 20, 2007 12:29 AM
Lichty17
Sep 25, 2005 11:54 PM
Paul1
Sep 10, 2005 01:57 PM
harvey
Jun 22, 2005 03:51 AM
Big Daddy
Oct 24, 2003 09:46 PM
