Swap engine and aircon components from 740 to 240
Old 02-05-2022 | 09:51 PM
volvo7480's Avatar
Default Swap engine and aircon components from 740 to 240
Hi,
I have found a 1984 diesel 240. Its chassis and all components seem perfect. But I don’t like diesel and it doesn’t have airconditioning also.
I can find a 740 petrol with airconditioning. Mu question is that, is it possible to migrating engine and airconditiong from 740 to 240 easily?
regards
Old 02-07-2022 | 07:55 AM
act1292's Avatar
The biggest problem is the location of the distributer. On MOST 740/940s the distributor was mounted on the rear of the head. The 240 does not have enough space between the firewall and engine for the distributor there and requires one mounted on the drivers side (US) front of the engine. There have been some 740/940s with the side mounted distributor so if you have one of those it should be no problem. You still would need an engine harness from a gasoline 240 as well as I expect your diesel harness will not work nor will the harness from the 740.
Ross Miner
10-27-2020 08:58 AM
thatwagonguy
03-05-2019 05:10 PM
davidguilbault
04-26-2016 01:56 PM
vcolper
01-29-2008 07:47 PM
jimnash
Engine & Internal
02-03-2006 05:52 PM
Quick Reply: Swap engine and aircon components from 740 to 240
