Swapping a 940 engine with a 240 engine
Old Feb 9, 2010 | 06:06 PM
rcartlidge's Avatar
Default Swapping a 940 engine with a 240 engine
Is this even possible or is it an easy task to change out an old tired 940 motor with a vibrant 240 motor?
By the way, I am not from Albania, I am from South Carolina.
Ron
Old Feb 9, 2010 | 09:13 PM
larry818's Avatar
They are probably the same motor. Everything should bolt up.
It won't be easy....
'cos engines are heavy...
Old Feb 10, 2010 | 10:48 AM
redbottle's Avatar
Use an engine hoist or cherry picker. Or since engine will be out replace the head gasket and install the red block first then the cyl head. Post pics while doing it
kg4ibj
Jan 9, 2014 02:28 AM
taygarde
Nov 19, 2012 09:03 PM
vonzai
Jul 1, 2011 11:19 AM
phaedrus
Jun 7, 2011 11:44 PM
lwrdr2
Nov 23, 2008 06:35 AM
