Temperamental transmission safety release
Old Jul 21, 2009 | 10:40 AM
jgc's Avatar
jgc
Default Temperamental transmission safety release
Hey -
I have a '92 245 automatic. After sitting for awhile, usually overnight, it takes a few minutes to get it into gear. I'm guessing there's a safety switch connected to the brake that must be sticking. Does that sound right? And if so, is it something I can access and replace myself? I looked up under there with my trusty WD-40 can in hand, but couldn't really see an obvious switch.
Thanks.
Jeff
Old Jul 21, 2009 | 12:26 PM
bubba240's Avatar
There is a solenoid that sticks but it has a manual release inside the cover.
http://www.volvo-forums.com/index.ph...opic=24383&hl=
Are you refering to this:
Condition: The gear selector can not be moved from the P position
The gear selector is locked in the P position. To release the selector, the ignition must be switched on (ignition key in position II) and the brake pedal must be depressed.
Depress the brake pedal
Select a gear
Release the brake pedal
If the gear selector cannot be moved, check fuses 7 and 12.
P-position lock
(SHIFTLOCK RELEASE)
Manually releasing the gear selector
If the car's electrical system is not functioning, the gear selector must be released manually. The catch is located under the brushes in the gear shift cover (see illustration).
Push the catch gently to the left.
Select a gear
Old Jul 21, 2009 | 10:55 PM
jpravi8tor's Avatar
Default solenoid release switch
gentlemen is this not the switch mounted on the brake pedal?(lower switch) this one can be adjusted.
Old Jul 21, 2009 | 11:00 PM
blue goose's Avatar
Jeff, have you checked the fluid level in the tranny?
Old Jul 22, 2009 | 08:43 AM
jgc's Avatar
jgc
I think the solenoid beside the shifter was sticking. Per some of the solves from that earlier thread you directed me to, I took the cover off and sprayed inside the solenoid with WD-40. Seemed to loosen it up. I'll know tomorrow for sure after it sits overnight. Thanks for the help.
farmer john
Oct 29, 2011 11:08 AM
Heath7
Mar 13, 2011 11:09 PM
mcmuggles
Feb 25, 2009 11:54 PM
waldos960
Jan 3, 2006 09:01 PM
salkenn
Nov 19, 2005 02:59 PM
