Thermostat question
RE: Thermostat question
Standard thermostat is 89 C. Easy enough to change.
Ask before buying, the Volvo OE parts come with the seal around the 'stat, others may not.
The reason for Tech's question, if the engine temp (as indicated on the dash gauge) is proper, it should run the consistantly once warmed up.
I'm curious, what do you mean by "it just runs different"?
