a thump when braking
Old Aug 31, 2007 | 01:23 AM
Beardog's Avatar
Default a thump when braking
Allright the idle is running high and the car wants to push the vehicle easily as if its getting more gas then i think i'm giving it. the problem seems to be when i brake. not when i brake lightly and not when i brake real hard, just when i brake moderatly under normal braking conditions. The thing is, i feel a small thump just before the car comes to a complete stop. I feel as if there is something wrong with the brakes, but then I'm thinking it is something to do with the transmission. as if the high idle isn't allowing the torque converter to let the transmission go until im almost stopped and then it lets go. well thats my current feeling.
any insights would be appreciated.
Old Aug 31, 2007 | 02:37 PM
funnyguy44444's Avatar
Default RE: a thump when braking
Well an easy way to test that is to put the car into neutral when you start braking. If it still thumps you know you have a brake problem, if it doesn't you have a problem in your drivetrain.
Old Sep 2, 2007 | 03:20 AM
Beardog's Avatar
its not the brakes. It has to do with the high idle problem and the torque converter.
Old Sep 2, 2007 | 11:48 AM
I would check to make sure that torque converter has enough fluid in it. They rarely leak but that migh be yur problem. How high is it idleing? You should fix the high idle problem and then you will know if that is your problem. What year and model is your car?
Old Sep 2, 2007 | 11:55 AM
Beardog's Avatar
the details can be found under the thread "high idle" started by me in this forum. Anyway, its a '89, 740gl with a 230f engine and at start up it is about 1250 rpm and after it warms up it drops down to 750 rpm. The thump isbarely noticeblewhen the idle drops to normal rpms and is in gear. It is non existant in neutral. If the engine is warm the vehicle doesn't go into high idle. my feelings are that it is the coolant temperature sensor or the MAF. It might still be a vacumn leak, but I don't see any loose hoses.
Old Sep 2, 2007 | 11:57 AM
Beardog's Avatar
please post your thoughts onthe high idle problem under the previosuly mentioned thread.
BTW thanks for the advicefunny guy it is much appreciated.
Love_my_Volvos
May 8, 2009 11:07 PM
V70Pinner
Jan 22, 2009 02:11 AM
micfoo2002
Jul 30, 2008 07:25 PM
undercoverwalrus
Jan 21, 2008 11:06 PM
markjenross
Nov 15, 2007 03:33 AM
