Tire size, Tach and speed
Old Apr 2, 2010 | 06:33 PM
lwrdr2's Avatar
Default Tire size, Tach and speed
Ok after being gone for a while I ended up buying a an 88 740GLE wagon. Nice car but i noticed something. The pervious owner had replaced the 185/70/14 tires with 195/70/14. I know not a huge difference but when im doing 65 the tach is reading around 26-2700 rpm. Is thins inthe ballpark of being correct or is the learger tires throwing off the tach reading that much. My Minivan and truck even though they have a v6 runs around 2-2100 rpm. even the 4cyl Kia optima doesnt run that high at that speed. Any thoughts?
Old Apr 2, 2010 | 10:12 PM
tedv's Avatar
That's normal for your car. A v6 or a v8 will generally turn slower as will newer cars geared for economy.
Old Apr 4, 2010 | 08:53 PM
DavesVolvo's Avatar
I don't see how the width would affect the tach. Diameter, yes, but contact patch, no. You're only talking about 1cm of difference in width from the original tires.
Old Apr 6, 2010 | 07:43 PM
swiftjustice44's Avatar
Ok...that little change in tire size, that insignificant change...well let's just see...
185/70/14
sidewall 5.1"
diameter 24.2"
circumference 76"
revolutions per mile 834
195/70/14
sidewall 5.4"
diameter 24.7"
circumference 77.7"
revolutions per mile 815
Assuming you're speedometer was accurate originally, now when you're traveling 60 mph according to the speedo, you're actually traveling 61.4 mph, meaning the speedo is 2.3% off.
A much better size would be a 195/65/14 where the speedo is barely affected.
And no, I'm no tire guru...I have a tire calculator web site in my favorites...
http://www.miata.net/garage/tirecalc.html
4cfed
Apr 26, 2010 12:14 AM
cliffw2000
Apr 10, 2010 11:21 PM
obaloney
Nov 15, 2008 05:22 PM
HummerGuy
Oct 10, 2008 08:02 AM
van850
Jun 21, 2006 03:24 AM
