tranny whines & slips when cold
Old Nov 30, 2006 | 12:40 PM
dtupac's Avatar
Default tranny whines & slips when cold
Hi everyone,
Need some advice, 89 240 GL, when i bought it the previous owners had neglected it and failed to realize the car takes fluids. I had to completely fill the transmission with Dexron III. Since then it has whined on and off at startup and this morning believe it or not it was actually cold in arizona and the tran was slipping some and not shifting properly....i plan on changing the filter soon could this have anything to do with it i.e. being so clogged it can't pass fluid thru till its cold? or is my torque converter going? any help would be appreciated. It still drives good just don't want to change the tranny if i don't have to right now.
Old Nov 30, 2006 | 02:35 PM
dtupac's Avatar
Default RE: tranny whines & slips when cold
also when warm
Old Nov 30, 2006 | 08:39 PM
The tranny is most likely going bad.
Old Dec 2, 2006 | 12:53 PM
dtupac's Avatar
Question,
Would anyone try flushing the tranny first or replacing it. I've located a new transmission but wondering if possibly this one is just gunked up.
Don't want to spend money on the tranny if it's good, and don't want to waste money on flushing it if that's not the fix either.
It still engages but barely, the fluid is burnt and it's less than a month old. Won't do over 40 and when it is it's at 4k rpm
thanks for opinions
Old Dec 2, 2006 | 01:39 PM
If the fluid is only 1 month old then a flush will not help.
Old Dec 2, 2006 | 02:38 PM
dtupac's Avatar
it wasn't completely empty, put in 2 qts. wondering if it sucked up the crud in the tranny, it didn't whine or shift funny till i put fluid in it
Old Dec 2, 2006 | 04:20 PM
No I doubt it the trans. sounds like it is shot.
Pej
Jan 4, 2014 12:44 AM
jhorton
Oct 30, 2012 06:06 PM
Rosy
Sep 18, 2010 10:15 PM
2000 V70
Jun 7, 2010 02:46 PM
Kenwood
Feb 12, 2009 10:24 AM
