Transmission problems, 940 turbo.
Old Nov 23, 2009 | 10:42 PM
cosmo's Avatar
Default Transmission problems, 940 turbo.
Hi. The transmission has gone on strike and is not transmitting. It sort of grabs a little off and on. The fluid looks kind of brown and doesn't have any of the red colour in it. Do you think a fluid change and filter change would get it back on the road, and would that be a difficult affair? If doable, how should I proceed? It is a '91 940 turbo sedan 4 door. Thanks in advance.
Old Nov 24, 2009 | 04:37 AM
Typhoon's Avatar
I'd flush the transmission several times, but I would pull the pan as well to do it. Buy a new filter and pan gasket.
If you find lots of metal filings and brown slurry in the bottom of the pan, budget for a rebuild.
They're fairly cheap transmissions to rebuild.
Regards, Andrew.
jeffrisley
Jun 14, 2015 01:48 PM
flgal
Aug 28, 2012 08:05 PM
Jakeness
Oct 18, 2011 09:36 PM
ogotaj
Mar 22, 2008 02:57 AM
VolvoNewbie
Nov 7, 2004 10:21 PM
