Transmission shift solved
Old Jan 29, 2007 | 07:13 PM
daver80's Avatar
Default Transmission shift solved
89 240 automatic, was having trouble shifting into high gear. problem was-The kick down cable was caught around something on that drum that the throttle cable goes around. straightened it out, everything OK. 5 second fix. Hooray!
Old Jan 29, 2007 | 07:27 PM
JetTech's Avatar
Default RE: Transmission shift solved
Don't you just love it when a problem is fixed that easy......Good for you!!!
Old Jan 30, 2007 | 03:17 AM
daver80's Avatar
Yes, I do and here's the icing on the cake- When the problem first surfaced, I called the local saturday morning car care show on the radio. as soon as they heard '89 and 200k, their responce was "what you need is a new transmission. See, the seals are worn and that is why it wont shift into high. It will be about 1500. Why we always say not to buy a 1200 $ car......" I plan to call them this Saturday, wish me good luck... Dave
Old Jan 30, 2007 | 08:45 PM
The first thing I would have said was to check the adjustment on the cable.
abro
Oct 4, 2013 03:50 PM
tngreg
Dec 3, 2007 06:05 PM
likesspace
Jun 18, 2007 09:14 PM
kartman01
Dec 20, 2005 11:49 PM
