Troubleshooting Sunroof?
So the sunroof in my 940 wagon doesn't work...as far as I know. But it hasn't worked since I got it and it would be a simple fix or a monumental issue. When I hit the button to retract it nothing happens. I'd love to get this working again, but I really have no idea where to start aside from checking all the fuses, which i've already done.
Any thoughts?
Any thoughts?
It is probably the motor. If you remove the plastic cover that covers the motor, you will see the power connector that connects to the motor. Remove this and see if there is power there by placing the red lead to one of the power spades and the other black lead to the motor. If there is power, it is the motor. If not, it is the rocker switch.
I'll try my hand at cleaning the switch and see what happens.
