turn signal switch?
Old Feb 16, 2007 | 01:29 PM
Kruspe31's Avatar
Default turn signal switch?
Now my turn signals dont work. They work for a little while then they all stop, right/left/hazards. All the other lights work. Now I went and searched for some answers and I saw a post that said maybe ingition switch? if so where is that on my car? Or is there a relay for the signals?
Old Feb 16, 2007 | 04:14 PM
TedH's Avatar
Default RE: turn signal switch?
the ignition switch may be a problem but not likley, there are relaysfor your turn signals. the relays may be getting hot and sticking open, i would check them before you do any thing about the ignition switch.
Old Feb 18, 2007 | 11:21 PM
Kruspe31's Avatar
well i figured it out, its a loose connection. I found out today that the where the signal switch is loose. I never knew that before so I start messing around with it. and all the signals/hazards started to work. They cut out again but rarely but then I got it to work. I tired tightening the torx screw with a t 10 but helped a little. So is it worth it to buy a used signal switch and having them install it, or wait till this one dies out if it doeS?
Old Feb 20, 2007 | 01:03 AM
Kruspe31's Avatar
to replace the turn signal switch do I have to remove the whole wheel? I noticed it has 2 torx screw on top do I remove those and not the wheel?
Old Feb 20, 2007 | 01:16 AM
Some you can remove after removing the covers.
Some you have to remove the wheel.
Old Feb 20, 2007 | 01:31 AM
Kruspe31's Avatar
well the cover i pulled off a little bit. and it fixed it for a little while but then it stopped all of a sudden. So I dont think the wheel has to come off but im not the mechanic. I will bring it to his shop my mechanic and see what he says thanks.
Old Feb 24, 2007 | 07:57 AM
Kruspe31's Avatar
thanks for all your help I got it to work. It did need a new relay. so I got one from autozone installed it and the signals/hazards work again. yay
Old Feb 24, 2007 | 03:34 PM
Kruspe31's Avatar
one more thing on my car is the fuel pump realy white? I know its stamped, but I dont know the color. And when I put in the new flasher relay, i saw a stamped date that said 1-30-90 and since that part is original I would like to change it.
Old Feb 24, 2007 | 04:33 PM
Yes the fuel pump relay is white.
It looks almost like a double wide relay.
jimbob1
Oct 27, 2012 12:44 PM
wjkjr
Sep 29, 2012 07:33 PM
LUPike
Jul 18, 2011 04:56 PM
sjp960
Feb 3, 2010 02:41 PM
Adrenalin540
Nov 7, 2008 07:24 PM
