Multi function switch (turn signal) removal
Old Nov 7, 2008 | 01:35 PM
Adrenalin540's Avatar
Default Multi function switch (turn signal) removal
Can somone help me I don't want to break my shroud, how do you get the shroud and multi function switch...turnsignal off the steering column?
Thanks
Old Nov 7, 2008 | 02:28 PM
Default RE: Multi function switch (turn signal) removal
looking from under the column there is hole towards the front like close to the steering wheel. There is T-15 screws way up there. Remove them. When you start to loosen them push down on the top cover to hold things tight so hopefully the top cover won't break.
Then there is T-25 screws from underneath remove them and slide the covers off. Then 2 T-25 screws hold the switch on.
Old Nov 7, 2008 | 04:27 PM
I got the 2 t25s out of the cover but only the back of the cover seperates...havin a hell of a time findin a crank postion sensor...
Old Nov 7, 2008 | 04:32 PM
You need to remove the 2 T-15 screws way up front they are deep in the holes.
Old Nov 7, 2008 | 07:12 PM
Tech...thanks! That did the trick. I'll be able to pull my next stalk in <2 mins next time :-)
Old Nov 7, 2008 | 07:24 PM
Glad I could help!
jimbob1
Oct 27, 2012 12:44 PM
wjkjr
Sep 29, 2012 07:33 PM
LUPike
Jul 18, 2011 04:56 PM
sjp960
Feb 3, 2010 02:41 PM
Kruspe31
Feb 24, 2007 04:33 PM
