Unknown Territory - 740 Spark Plug change - Noisy Engine
Old Oct 22, 2015 | 10:32 PM
  #21
michael9898's Avatar
Thumbs up
Originally Posted by jagtoes
The thread chaser should do the trick. Just use grease on it as you thread it into the hole. Take your time and it should work out. Also use anti-seize on the plugs when you install them. Next I would remove the fan unit and start the engine again and see what noise you get. As for the lower balance pulley I've replaced mine as the rubber rots with age. You can tell by removing the belts and then try to move the balancer by hand .
Well, I cleared out my afternoon and popped open the hood today. Using that $12 thread chaser I cleared out the threads of the spark plug hole and my NEW volvo spark plug went right in like butter! Oh it took some work. I gained a thread here a thread there. I took my time, 4 hours to be exact, but I took breaks, enjoyed the outside and even had a glass of merlot.
I fixed the spark plug hole! Whoohoo!!!
I believe it was a combination of having dirty threads and there were some tiny pieces of threads that came out about 2 hours into it. I was super delicate though. As delicate as I could be. Like I said, a thread here a thread there. Slowly I made progress.
I'd get the thread chaser to the point where it would start resisting and i'd give it a little more force then i'd back out, go a little further, then back all the way out, shop-vac the hole and brushed off any dirt or metal from the chaser using a wire brush.
I lubed the thread chaser every other time with a small amount of oil and back in it went, each time making more progress. In between this I would occasionally take the old/original spark plug and i'd install it a little by hand, just to see. Eventually the threads got so clean that i was able to screw down the spark plug most of the way with my fingers... the way i think it should be. I finished by taking the new plug... the one that I was trying to install from the friggin' beginning... and it went right in. No problems!
I was so happy. The car started right up and I let it idle for about 30 minutes. Now I can tackle some of that noise.
Hey thanks to everyone for your help. Just openly discussing some of this as I encountered it was a big help.
Jagtoes & Dytha, I'm going to try what you said. I'll take the belts off and see what I get and I'll record it for all to see. I'll also take a better start up video and another when the engine is warm and has been driven a while. I'll update this post when I do.
Oh and I'm using 10w-30 oil. What do you guys use on yours?
Old Oct 22, 2015 | 11:13 PM
  #22
10W30 for most climates. if you live where its 100F+ all summer, 10W40. if you live where its sub-freezing most of the winter, there's some lighter weights approved but you should change back to 10W30 before driving above 60F any significant distance.
henrysin44
Dec 9, 2014 09:14 AM
Tuunikala
Jul 20, 2014 02:41 AM
djwhizkid
May 7, 2010 06:32 AM
futbolfan15
Apr 2, 2010 09:56 PM
