Vacumn Leak
Old Jun 20, 2006 | 09:18 AM
RedBrick's Avatar
Default Vacumn Leak
I want to replace the vacumn hose from the intake manifold that runs into the firewall below the brake booster. Is this connected to a valve on the brake booster and can it be easily replaced (the valve) when i change the vacumn hose. Dont see this valve on the outside of the firewall. Is it accessible from the inside under the driver well?
I have a studder and die (only does it one time) when starting the car stone cold and putting the foot on the brake to put the car in gear. The vacumn line is pretty brittle and like I said it runs into the firewall below the brake booster. It is about three feet long.
Thanks
RedBrick
1992 GLE 745Ti 106,000
Old Jun 20, 2006 | 11:50 PM
Default RE: Vacumn Leak
Not sure what that hose is for.
The brake booster hose goes into the top of the Booster.
The stalling on first start might be a Dirty Throttle body.
Old Jun 21, 2006 | 05:13 PM
jae17's Avatar
I'll second the dirty throttle body. "Studder and stall" on my '90 240 was fixed with this relatively simple and inexpensive cleaning. It's a DIY if you're a little handy; $60-75 if a shop does it. Usually done as part of a tune-up I'm told.
Jim
Old Jun 14, 2012 | 11:30 PM
Megatone60's Avatar
Where can I find a diagram of my vacumn lines on a 1987 Volvo 740 B2300
Old Jun 14, 2012 | 11:42 PM
on a sticker under the hood.
there's way too many variations for them to be detailed in any manual.
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
bigdawg1960
Nov 9, 2013 05:03 PM
jeybotz
Mar 2, 2012 07:24 AM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
