vacuum leak.. help!!
Old Nov 15, 2010 | 02:07 PM
91brickwagon's Avatar
Default vacuum leak.. help!!
Hello.. I'm a noob when it comes to volvos.. i just bought a 91 240 wagon and have been trying to pinpoint a vacuum leak.. the engine revs high at idle and i can hear a hissing noise so i know there is a leak somewhere... anyone know of a good diagram for vacuum wiring? how probable is it to be the upper intake gasket? i have sprayed carb cleaner on top of the intake and it seems to rev up a little. any help would be greatly appreciated.. i'm ready to get this thing running right.. i hear they are very reliable when tuned right.
Old Nov 16, 2010 | 06:35 AM
act1292's Avatar
It sounds like you may have found a leak if the idle increases. There are two places that can be suspect. First is the actual intake manifold gasket. Second is the o-rings that seal the fuel injectors. See if you can pinpoint which it is by spraying the carb cleaner around the injectors vs. the intake manifold gasket. Then replace accordingly. I don't believe either is all that expensive or difficult to do yourself.
robnov
Oct 6, 2007 05:03 PM
nick54
Dec 21, 2006 07:21 AM
pc142
Oct 17, 2006 03:37 PM
speedwagon
May 26, 2006 12:09 PM
hordezla
Apr 14, 2006 08:59 PM
