Doing some work this weekend, cam seal and oil trap
Old Nov 16, 2010 | 08:06 AM
volvoQ's's Avatar
Default Doing some work this weekend, cam seal and oil trap
Ordered parts from FCPGroton, hope they come in this week so I can work on it this weekend.
To replace camshaft seal I need to?
1. remove timing belt cover
2. release tension on timing belt
3. remove camshaft pulley
4. remove and replace seal
Anything else? What type of grease should I use on the camshaft seal and where? Also, do I need to "lock" the camshaft to keep it from jumping or otherwise check marks?
To replace oil trap I need to?
1. remove intake manifold (or do I) and release fuel pressure
2. remove and replace oil trap
anything else?
Thanks for the help!
Old Nov 16, 2010 | 10:49 AM
regime's Avatar
Just thinking out loud here... You may need a puller to get the pully off the cam shaft, while your in there it may not be a bad idea to the the timeing belt too... and the other 2 sealls i guess too...
Just rub a little motor oil on the seals before you put them in. (like you would on an oil filter gasket)
I would line up your timing marks. If you dont... you will probably have to later.
Its a non interferance engine, so if you didnt line it up, and had to spin it later to get them lined up, it wouldnt be a big deal, but its probably just easier to do it first.
boarders123
Jun 23, 2012 09:16 PM
JimKW
Feb 21, 2011 10:18 AM
STREETFIGHTER50
Apr 2, 2009 06:55 PM
ricardonz
Jun 10, 2008 09:31 AM
Shaun Oriold1
Oct 11, 2006 01:18 AM
