Vacuum Leaks - this might help
Old Mar 6, 2025 | 04:48 PM
Moetheshmoe's Avatar
Default Vacuum Leaks - this might help
My '93 940 Turbo had a great idle while it was cold but once warm it dropped enough where it was just above stalling(about 600-650). Once I gave it gas no problem but stop signs had me revving the engine just in case. I tighten up the clamps on all the vacuum hoses thinking there might be a leak. No change. Then I came across this youtube video about doing your own smoke test, which is really the only way to find very small leaks. And sure enough a small puff of smoke was escaping just below one end of the idle control valve. I tightened up a new clamp and the problem was solved. Great warm idle now. And I didn't have to pay $1000 dollars for a smoke machine. I did buy that cheap air pump from Harbor Freight but I'm sure it will have a lot of uses.
Old Mar 9, 2025 | 12:25 PM
admasters's Avatar
awesome, thanks!
Old Jul 3, 2025 | 08:11 PM
One end to the Other's Avatar
I have a 93 240 that needs the smoke machine test. Where would you hook it up? Thanks
Old Jul 4, 2025 | 08:01 AM
Disconnect any vacuum hose connected to the manifold and connect the 'smoke machine' to that inlet on the manifold.
Old Jul 4, 2025 | 11:26 AM
Thanks Moe! Happy 4th! I remember the Shmoe!
volvo-tinker
Sep 17, 2021 05:17 PM
lightstamp
Jun 25, 2021 11:23 PM
rcvolvo
Jul 8, 2013 08:46 AM
mhphoto
Mar 26, 2008 07:30 PM
jquick1
Aug 8, 2007 12:52 PM
