Volvo 240DL - Strange Electric Problem
Old Jun 14, 2013 | 01:51 PM
240DLighted's Avatar
Default Volvo 240DL - Strange Electric Problem
After parking for only 2-3 minutes, I turned the ignition to no start. The dash lights came up and I could hear the starter click, but no turn. I found no error codes, disconnected and reconnected the negative battery lead, and cranked a couple more times. Out of frustration, I held the key for a moment and the car started right up.
After getting home, I tried starting again to no avail. The dash lights still come on, but the windows don't roll up.
It's especially hot out today, making me think a bad relay - but why wouldn't the windows roll up?
Old Jun 14, 2013 | 03:42 PM
lev's Avatar
lev
If you heard the starter just "click", then it's a bad starter. The windows are fused, so may be a bad fuse...
Old Jun 15, 2013 | 12:57 AM
analogies's Avatar
I had the same thing happen to me....the wires to the starter solenoid were not making good contact, lots of oil....I ended up re-doing the entire engine bay wire harness....and cleaned the solenoid contacts...in my case the starter cranked nicely and it's been a month with no problems......I got a crack in the cylinder head but that's another story.
Old Jun 15, 2013 | 05:01 AM
could be a flakey ignition key switch, too.
Old Jun 15, 2013 | 07:55 AM
Travanion's Avatar
Could be low voltage too. I would check the battery also.
240DLighted
Nov 2, 2013 04:51 PM
codynidaho
Jun 6, 2011 10:02 AM
bmac
Apr 28, 2011 05:40 PM
Kruspe31
Feb 27, 2008 08:53 PM
toshields
Dec 8, 2007 04:50 PM
