Volvo 740 no spark
Old Dec 11, 2022 | 02:59 PM
Makozi's Avatar
Default Volvo 740 no spark
740 B230F
The engine is not starting and is not getting any spark.
I have replaced
- sparkplugs and wires
- coil
- distributor and rotor
- ignition module
- crank sensor
Old Dec 11, 2022 | 04:49 PM
Do you have 12v at the coil with the key on? Do you have a flashing test light on the other coil terminal when turning engine over? Do you have 12v on one terminal at the injectors with key on? Does your car have a black 4 terminal noise suppression relay mounted on the left inner fender as pictured below? (If present that relay sends power to the coil and the injectors)
Old Dec 13, 2022 | 02:19 PM
Makozi's Avatar
I have 12v at the coil with the key on, and i have a flashing test light when turning engine over. I also have 12v on one terminal at the injectors with key on. The car does not have a 4 terminal relay.
Old Dec 13, 2022 | 02:28 PM
Originally Posted by Makozi
I have 12v at the coil with the key on, and i have a flashing test light when turning engine over. .
Then you should have spark - -
Does your noid light flash when plugged into an injector wire?
Makozi
Dec 11, 2022 02:57 PM
oldfolks1
Apr 15, 2018 12:35 PM
weber
May 27, 2010 08:20 PM
am7kel
Jul 15, 2008 10:19 AM
Captain
Nov 13, 2007 09:22 AM
