Volvo 940 Brake Lights
Old Jan 30, 2021 | 07:26 AM
Snosnier's Avatar
Default Volvo 940 Brake Lights
Hello. My 945 prefl brake lights stopped working. I changed baggage doors and than it just happened. It's possible because of this? New doors was been from FL, but I changed cables as well. Only difference was been that FL had one connection for number lights, but prefl two. Bulbs are fine.. Fuse is getting burned after pushing pedal. Also fuse is getting broken when take out both bulbs and pushing pedal. What can be a problem? Relay or sensor from brake pedal, or there is more week points?
Old Jan 30, 2021 | 07:41 AM
lev's Avatar
lev
What are "baggage doors, FL, prefl"?
Old Jan 30, 2021 | 07:43 AM
Snosnier's Avatar
Trunk doors, aka baggage doors, 5ft door. 😅
Prefl - pre Facelift till 94, guess April
FL - Facelift aka 94+
Old Jan 30, 2021 | 08:43 AM
lev's Avatar
lev
OK, we don't have "face lift" 940 in the US, here unfortunately the 940 was not imported after the 1995 model year, and the baggage door is a "tail gate".
If your lights were fine before the change, then something now is not connected correctly. The license plate lights should not be causing this. I'd look for a short somewhere in the brake light circuit, The only relay is the check lights relay (big double stack one) which might be responsible but usually it just goes out causing no brake lights at all. May be you should take that relay out and see if the fuses still burn out. You won't have brake lights without it but you'll get some ideas. The brake light switch above the pedal could be bad and causing a short too...
Old Jan 30, 2021 | 09:49 AM
Snosnier's Avatar
Changed 7 relays and the same. After pushing brakes fuse goes kaput. Signal goes to tail lights. Changed cables next to bulb and it works in bright mode. Have double bulb..
Old Jan 30, 2021 | 11:36 AM
lev's Avatar
lev
Which 7 relays did you change? The Check Lights one too?The bulb you refer to is the brake/turn signal one and it usually does that when the wiring is wrong or a ground is bad. You must have a short in the brake wiring somewhere.
Old Feb 3, 2021 | 07:10 AM
Snosnier's Avatar
For lights is just one. Still thinking why the are in different colors. I have white, in collection also green and yellow. Most of the other hars have red.
I think I will change all cables for tail lights from another brick and than will see
Old Feb 3, 2021 | 11:58 AM
lev's Avatar
lev
Well, don't classify relays by colors! Use numbers or the diagrams usually stamped on the relays.
grizzly32
Mar 24, 2016 10:05 AM
stonepa
Mar 17, 2009 07:23 PM
g2b2
Jul 25, 2007 04:55 PM
stephen945
Dec 7, 2006 01:09 PM
grocerygetter
Jun 29, 2003 11:57 PM
