Volvo 940 cold start problem.
Old Jan 15, 2019 | 05:31 PM
Zem4243's Avatar
Default Volvo 940 cold start problem.
Hi! I am new to this forum and I really need someone's advice. So I have a 1993 Volvo 940 Rex Regina system mixed with Bosch. Anyways, I am having trouble with my car in the mornings. This started about a week ago and this is what happens:
So I turn the car on and all is well. However after 2 minutes of getting warm the car starts to act weird. The idle starts to go up and down, up and down, up and down, and it starts to sound like a cammed muscles car 🤣. It's pretty annoying. It also idles up to 1,000 rpms and sometimes goes up to 1,500 then back down and starts to go up and down up and down. However after getting 1/4 warm it settles down and goes back to normal. Car drives well and doesn't act strange when completely warm. I want to figure out what's going on before it get worse.
I have changed:
Vacuum lines
Pcv lines
Fuel pressure regulator
Cleaned IAC and even got a buddy to let me test his.
I've changed pretty much everything to do with vacuum lines. I even sprayed around with starter fluid to see if there were leaks somewhere.
I cleaned my MAF
Does anyone have any suggestions?? I literally running out of hope. This car has been in my family since 93 and would like to keep it that way.
Old Jan 18, 2019 | 06:21 PM
tylswil's Avatar
Is it throwing any codes?
Old Jan 18, 2019 | 06:32 PM
lev's Avatar
lev
It may be still the MAF sensor--cleaning it rarely helps. It could be the Coolant Temperature Sensor.
Turn the car off when this is going on, unplug the MAF, see if there is any diff. once plugged back in and running.
Old Jan 18, 2019 | 06:39 PM
tylswil's Avatar
Alright sounds good. Thank you. I just had the MAF replaced cause that was my previous issue and boy did it give me a ton of trouble.
Old Jan 18, 2019 | 10:25 PM
Goldenblock's Avatar
Goldenblock here!!! Its your throttle position sensor... Check to make sure you hear a click upon opening/closing as you manually open throttle. It may need adjusting or replacing!! Oss
I also have regina bosch hybrid 1989 740 gl
Old Jan 19, 2019 | 03:03 AM
dytha99's Avatar
Clean the throttle body?
Old Jan 21, 2019 | 02:58 PM
Zem4243's Avatar
It does click. I had a buddy of mine readjust the throttle body but no help.
Old Jan 21, 2019 | 03:07 PM
Zem4243's Avatar
It throws a 233 code and 223 sometimes. I wondering if it is the IAC but that is rare. I adjust throttle body and even cracked open the TPS. I found one of the metal things that makes the tps click bent a little for some odd reason but I bent it back. I reassembled it back together however, it did not make a difference. Next thing I did with my volvo friend that is a mechanic is, we decided to try to put the hoses on the IAC all backwards and it seems to have fixed the "cammed" idling however, it started making the alternator make sounds, very odd. I honestly dont know what is happening with this car. Another thing that is happening now is the throttle seems to be sticking at 1,500 rpms when driving. if you are around 40 mph the rpms goes down but then goes back up to 1,500 and stays there. Essentially, feels like the car is driving itself. So now I have issues with idling and rpms getting stuck at 1,500 rpms. If you have the car all warmed up also and rev it passed 2,000 rpms the car will get stuck at 2,000 as well. Any clue? Guessing it could be TPS? Should I replace idle air control and temp sensor?
Old Jan 21, 2019 | 04:46 PM
the 'TPS' is just a microswitch, closed if the throttle is fully at idle, it enables the idle control circuit. some cars also have a microswitch for full throttle, this is less important
shur
Jun 22, 2015 03:20 PM
mcadek
Mar 12, 2015 09:20 PM
dobrosailor
Jan 20, 2014 08:39 PM
maximusdecimusmeridius
Aug 8, 2012 11:08 PM
crunch5868
Apr 13, 2008 07:14 AM
