Volvo 940s missing
Old Oct 27, 2013 | 06:20 AM
mosh's Avatar
Default Volvo 940s missing
Hi my 1992 volvo 940s estate is missing,it started to miss about 6 weeks ago then after i parked it up and drove it the next day had no problems until yesterday where it was missing bad after driving along.Also i had my windscreen washer jets cleaned yesterday and the tube put back on the windscreen washer pump.Also my speedometer is flicking up to 50-60mph when only going 2o mph or so then it seems to settle down after a while going back to normal speed.Plugs and leads the cause? Or another cause loose connection somewhere or a sensor maybe?
Any help appreciated got my mot in a week
cheers sean
Old Oct 27, 2013 | 08:43 AM
lev's Avatar
lev
An engine misfire calls for an evaluation, starting with what used to be called a "tune up"... Plugs, wires, rotor, dist. cap, etc. There may be other causes, however: vacuum leaks, fuel issues, bad head gasket, etc, but the ignition system tune up is a good place to start.
The speedometer issue is most likely due to bad capacitors in the speedo itself and there is no easy cure--need a new speedo or replace the capacitors which is a fiddly procedure in the best of cases. For some reason '92s are particularly afflicted with bad speedos.
Old Oct 27, 2013 | 09:28 AM
Old Oct 27, 2013 | 03:10 PM
lev's Avatar
lev
A '92 is an OBD1 car, the codes provided in the above post are for OBD2 equipped, so useless as usual...
Old Oct 28, 2013 | 10:30 AM
mosh's Avatar
Thanks for the advice
cheers sean
Old Oct 28, 2013 | 10:47 AM
fochs's Avatar
Default obd1
Volvo OBD Trouble Codes –
Old Oct 30, 2013 | 02:24 PM
mosh's Avatar
Hi guys me again i cleaned all around the ignition coil as when i started it up in the dark some blue sparks were coming from around that....no problems there now,but noticed today some sparks going along some spark leads around halfway down the leads any ideads ?
cheers sean
Old Oct 30, 2013 | 04:40 PM
Not really useless. The video shows how to check plugs, compression and other misfire related stuff. Did you watch the video or just read the title?
Old Oct 30, 2013 | 04:42 PM
If you see spark traveling around wires etc., it sounds like you need new leads.
Old Oct 30, 2013 | 04:59 PM
mosh's Avatar
Put my order in for new leads about a hour ago cheers for the help everyone.
Old Oct 30, 2013 | 06:31 PM
ideally, use bougicord wiresets, they are by far the best for these volvos, they meet the original manufacturing specs
mosh
May 11, 2014 04:26 PM
mosh
Sep 12, 2013 06:35 AM
aytchgee
Nov 20, 2009 12:11 PM
aytchgee
Aug 7, 2009 09:22 AM
otguk
Oct 2, 2004 07:59 AM
