warning lights illuminated '86 240DL
Old Sep 22, 2006 | 02:12 PM
jktiffin's Avatar
Default warning lights illuminated '86 240DL
While returning home from work yesterday the dashboard warning lights for battery and emergency brakes came on. Is this an electrical problem or something more serious? (They are flickering weakly). What could this be and what to do?
Thanks
Old Sep 22, 2006 | 08:41 PM
Default RE: warning lights illuminated '86 240DL
The Brush pack for the Alternator might be bad/worn.
Old Sep 23, 2006 | 06:05 PM
jktiffin's Avatar
Thank you. Does that mean the battery is not recharging? How would I know if that is the problem? Is it a simple fix or does it mean a new alternator?
Old Sep 23, 2006 | 07:37 PM
Check with a Milti meter and see what it is charging at.
If the brushpack is bad it is replacible. You can remove it look on the back of the Alt. Look for a Round black thing with a phillips screw on each side. Remove it and look at the Metal things sticking up.
If they are about 1 inch long then they are good. If they are less than 1/4 they are worn.
Old Oct 5, 2006 | 06:30 PM
jktiffin's Avatar
Thanks for the reply. Unfortunately I did not have the time to do this apparently simple repair myself so ended up paying $300 for a new alternator installed.OUCH!
104octane
Jun 11, 2009 03:04 PM
104octane
Engine & Internal
Jun 11, 2009 03:01 PM
parmbrust
Sep 20, 2007 12:51 AM
signofthetimes
May 27, 2007 02:22 PM
bhaven
Sep 7, 2005 09:21 PM
