waterpump replacement
Old Oct 24, 2006 | 12:19 PM
plopswagon's Avatar
Default waterpump replacement
The Bentley book says to use vasoline between the gasket, block and pump. Haynes says use RTV sealant. Any suggestions
Old Oct 24, 2006 | 03:51 PM
billofdurham's Avatar
Default RE: waterpump replacement
My Haynes manual says "a smear of grease". Go for the Vaseline.
Old Oct 26, 2006 | 11:09 AM
cbevis's Avatar
which is cheaper?
Old Oct 31, 2006 | 12:41 PM
Rule .308's Avatar
I have always used 3M spray adhesive to bond the paper gasket to the pump and put a bead of RTV in the groove for the top seal, squish the top seal in and use the residual that squishes out to smear across the top of the same seal and smear some inside of the hole that the by-pass pipe and gasket will go into. The wet RTV serves as much as an assembly lubricant as it does a sealant when it cures. Gluing the gasket to the pump simply facilitates the assembly and future disassembly when this pump craps out on you too.
Mark
nharms
Penta
Apr 21, 2011 03:15 AM
boxpin
Feb 23, 2010 10:32 PM
dlaxdal
Sep 12, 2009 10:58 AM
yank50
Feb 28, 2009 06:49 AM
plopswagon
Nov 1, 2006 10:35 PM
