waterpump 850 turbo
Old Sep 9, 2009 | 09:21 PM
dlaxdal's Avatar
Default waterpump 850 turbo
I have a 1995 850 turbo. If the waterpump was not working how can I tell. The car does not overheat and the heating blows hot on the interior. Is there a home test I can do to test the pump. I installed a new thermo a couple of months ago and when I changed out the tensioner and belt I did not do the pump because the forum said they were very durable. The car only overheated once this summer and I believe there may have been to much anti freeze and the cap was a little loose.
Any thoughts.
Old Sep 9, 2009 | 09:33 PM
gilber33's Avatar
If your water pump was not working you would know, the water pump failing leads to blown head gaskets and what not. I think your engine would be running pretty rough if your water pump wasn't working. But wait for a pro to get on and verify. That's just my 16 cents.
Old Sep 9, 2009 | 09:34 PM
woodsytf's Avatar
when a waterpump fails is normally spits/leaks coolant all over (often quickly emptying the radiator) the place, and if you dont notice the smell, the radiator warning lamp will come on when the expansion bottle gets low. and if you miss those clues... the temp gauge may climb, but it will be too late then as the temp sensor is now dry and will need a really eff-ing HOT block to make it wiggle.
Old Sep 10, 2009 | 09:18 AM
fcpgroton's Avatar
Former Sponsor
How many miles are on the pump? I am changing my out in the next 5000 miles when I do my timing belt. It will have 200K miles on at that point.
Old Sep 11, 2009 | 08:16 AM
dlaxdal's Avatar
123,000 is there much water flow normally. It does not leak water at this point
Old Sep 11, 2009 | 08:23 AM
gilber33's Avatar
That's really early for a waterpump to fail. My car has 214k miles and no failage.
Old Sep 11, 2009 | 10:09 AM
fcpgroton's Avatar
Former Sponsor
+1, you are still fine. You normally want to change them out around 180K.
Old Sep 11, 2009 | 10:44 AM
850tony's Avatar
meh, its a volvo, i dont replace it till it makes a noise or goes "SWEALANG!". seriously though, i usualy dont fallow what people "say" you should change it at. change it when the time is right.
volvo says do wheel bearings every 80k..... screw that.
Old Sep 11, 2009 | 10:55 AM
gilber33's Avatar
lulz. Same here. Except the timing belt, that's something I don't think you want to wait until it goes, how do you say, SWEALANG!
Old Sep 12, 2009 | 03:15 AM
850tony's Avatar
swea'-lang different word for SHINK! (like a timming belt breaking... SHINK!)
Old Sep 12, 2009 | 10:58 AM
gilber33's Avatar
SHINK! Followed by @#$% !!!!!!!
nharms
Penta
Apr 21, 2011 03:15 AM
boxpin
Feb 23, 2010 10:32 PM
yank50
Feb 28, 2009 06:49 AM
plopswagon
Nov 1, 2006 10:35 PM
plopswagon
Oct 31, 2006 12:41 PM
