Weird Vibration
Old Dec 27, 2018 | 12:48 AM
BlueStreak91's Avatar
Default Weird Vibration
I have a vibration on my 240 that shakes the entire car. Eases/stops when I let off the throttle, comes back when I’m on it. I’m thinking it’s the driveshaft carrier gone. Any other thoughts?
Old Dec 27, 2018 | 07:49 AM
act1292's Avatar
If the driveshaft carrier is gone - I assume you mean the rubber piece - then I would address that immediately. Since you must drop the driveshaft to fix the carrier, check all the u-joints to make sure they move freely with no play nor binding. You probably need to replace the carrier bearing when you replace the rubber piece.
Also, when you split the drive shaft, make sure you mark the front and rear sections as the shaft is balanced as one piece.
280zxNick
1998-2000 model year V70
Oct 22, 2015 11:18 PM
Soundbyte
Oct 11, 2010 05:29 PM
oddlots347
Jan 11, 2009 05:03 PM
GMad
May 22, 2008 05:31 PM
davemoffat
Apr 13, 2008 11:19 AM
