what should the compression be in the cylinders?
Old Jul 19, 2009 | 03:13 PM
Beardog's Avatar
Default what should the compression be in the cylinders?
what should the compression be in the cylinders? I don't want the ratio. I want the compression reading when you do the cyclinder compression test. I got about 200psi across all the cyclinders. which is good that they are all the same. I got this number by turning the engine over three times, and then repeating three times on each cyclinder.
b230f 1989
Old Jul 19, 2009 | 03:19 PM
blue goose's Avatar
Bentley says 128 psi minimum with 28 psi max difference between cylinders.
Old Jul 19, 2009 | 11:36 PM
Sofar.'s Avatar
The actual figure is unimportant, especially being as an inexpensive tester can be way off. 200 seems high but there's no way that's not just the tester.
royalslover
May 14, 2014 08:43 PM
boxpin
Aug 21, 2009 03:18 PM
enthuesd
Dec 27, 2008 07:05 PM
brentrite
Oct 27, 2008 11:37 AM
waxk
Mar 7, 2006 03:24 PM
