Loss of Compression in in Cylinders 2,3,4
Old Oct 24, 2008 | 12:24 AM
brentrite's Avatar
Default Loss of Compression in in Cylinders 2,3,4
I did a compression test on my '98 s70 2.4L non-turbo and and the middle three cylinders are virtually dead, car still has kick though. Cylinder 1 was 175 psi, 2 was 125 psi, 3 was 134 psi, 4 was 139 psi, and 5 was 165 psi. Could this be a blown head gasket? I would much rather it be that than valves or piston rings.
Old Oct 24, 2008 | 07:09 AM
Default RE: Loss of Compression in in Cylinders 2,3,4
I would try running valve cleaner through the system and drive it a little then retest.
Old Oct 24, 2008 | 12:10 PM
brentrite's Avatar
Alright ill give it a shot today, Thanks!
Old Oct 26, 2008 | 07:38 AM
d2jreality's Avatar
how many miles are on the car? when was the last time u changed the spark plugs? take them out and clean them or change them. look in the plug cylinders for any debree and or cracks. make sure plugs are tight then retest.
Old Oct 26, 2008 | 11:24 PM
brentrite's Avatar
it has 129,000 miles but i ran valve cleaner through the fuel system and it really seemed to do some good. I think this week im going to do an oil change and tune up. Thanks for the suggestions, they really helped!
Old Oct 27, 2008 | 08:06 AM
Let us know how it goes.
Old Oct 27, 2008 | 11:37 AM
FredMc's Avatar
I would get some of this stuff and add it to a new oil change.
very highly recommended
www.auto-rx.com
flatbrick
1998-2000 model year V70
Feb 9, 2014 07:01 AM
Beardog
Jul 19, 2009 11:36 PM
enthuesd
Dec 27, 2008 07:05 PM
waxk
Mar 7, 2006 03:24 PM
manicmechanic
Mar 4, 2005 06:55 PM
