What type of Steering Wheel Fluid for 240?
Old Jul 25, 2010 | 01:48 AM
dman777's Avatar
Default What type of Steering Wheel Fluid for 240?
What type of steering fluid should I put in my 1990 Volvo DL 240 that has power steering? Mine is running a little low.
thanks,
-dman
Old Jul 25, 2010 | 02:50 PM
stojakovic's Avatar
You can use ATF type F. If it comes with dirty PS fluid, you can drain and fill several cycles to replace the old fluid.
Old Dec 25, 2021 | 10:30 AM
91Volvo240survivor's Avatar
The best option. https://pilotshq.com/products/royco-...4f69f50e&_ss=r
thanks,
-dman
Old Dec 25, 2021 | 12:48 PM
lev's Avatar
lev
Type F.
You should change it if it's dark grey or worse. It should be reddish; many don't bother but good fluid keeps your steering rack alive longer.
Old Dec 26, 2021 | 11:50 AM
Easy way to change PS fluid: Buy 1 quart of fluid (owners manual should give a spec as well). Use a turkey baster with a short section of rubber hose added (or similar suction pump) to pull the fluid out of the reservoir. Refill with fresh. Start the car, turn lock to lock 5X to circulate the new fluid in the reservoir down into the rack. Repeat 3-4X until you are almost out of fluid (leave enough to top off). That should get you to about 80% clean for under $10.
Porkchop99
Feb 17, 2011 04:30 AM
Francis
Sep 26, 2008 02:45 PM
dman777
Dec 25, 2007 06:47 PM
nmwagon
Aug 29, 2007 05:14 PM
werdnash2002
Dec 13, 2006 12:12 AM
