Why isn't there a sticky?
Old Jan 23, 2021 | 05:53 PM
Stinky's Avatar
Default Why isn't there a sticky?
Really simple, there isn't a Sticky on how to change the timing-belt. AND, when I did a search, I stopped after about 3 pages of not finding anything.
There also isn't a Sticky on torque values....what i am looking for is the Camshaft nut and the Idler nut. I guess I'll look at my 850 manual and assume that the nuts have the same size bolt attached to them.
My manual ran off and hid...how the hello can a manual 4" thick, and 8.5x11 disappear?
Old Jan 23, 2021 | 08:04 PM
the 850 motor is *very* different than the B230F(T) in 240/740/940...
there's tons of useful info in the 7XX/9XX FAQ here, https://www.volvoclub.org.uk/faq/FAQSummary1.html
240's have the same engines and transmissions so much of it is directly applicable.
Old Jan 24, 2021 | 08:31 AM
lev's Avatar
lev
If you just put "Volvo 240 timing belt R&R" in your search all kinds of sites will pop up...
Old Jan 24, 2021 | 10:32 AM
Stinky's Avatar
That is not the point. The point is that this site is lacking. If you do a search on THIS SITE, you won't find it.
I am a member of odyclub, crvownersclub, toyotanation, infamousnissan, ratsun, and others, and in the past frequented a mpvforum. They all have that sort of information.
On toyotanation, there is a link, in the FAQs that shows you how to do a complete in the car rebuild (to fix a factory defect w/Corolla pistons).
Youtube has a wealth of information...but usually no torque values, not even on the IDP link.
Old Jan 25, 2021 | 09:15 AM
are you asking if you can author a thread on a how to or how to google for online documentation? Assuming the latter is more directly what you need, you can start with volvotips.com which has various shop manuals posted for 700/800/900s etc. You can also google to see if somebody posted a PDF of a Haynes manual ie google "volvo740 repair manual PDF". you can also build a set of bookmarks for other boards like turbobricks, matthews, swedespeed etc.
See if this helps: https://www.brickboard.com/FAQ/700-9...CamReplacement
1995Volvo850
May 12, 2012 09:15 PM
schnellcgw
Jul 29, 2011 09:33 AM
MC92
Jul 18, 2010 12:21 PM
davelarue
Oct 4, 2007 05:51 AM
michaelmorris
Jan 24, 2006 10:52 AM
