Wipers come on when I turn on the headlights (posted in July 2010)
Old Jul 10, 2010 | 04:40 PM
lipsro1's Avatar
Default Wipers come on when I turn on the headlights (posted in July 2010)
I have a 4 cylinder 1987 Volvo 740. The wipers just started coming on when I turn on the headlights. I've unplugged the wiper motor and sprayed WD40 and plugged it back up to get out the moisture. No luck.
Old Jul 14, 2010 | 05:17 PM
No clue. The wiper control is not the same switch as the head light switch. Maybe you have a bad relay somewhere. So, when you turn the lights back off the wipers go back off? If that is the case, my guess would be that you have some bad wires somewhere and the coating has come off of the wires and you are making contact on bare wires.
Those cars should have been recalled because of the wiring that Volvo used to wire the cars with. The wanted to be "eco friendly" or "green" and used wires that were made of a recycled rubber coating. Well, the coating started deteriorating to the point of coming off the wires. You touch them the the rubber just falls off. Lots of Volvos burned to the ground because if it.
Old Jul 14, 2010 | 05:18 PM
You should have posted this in the 240, 740, 940 section.
Old Jul 31, 2010 | 01:39 AM
Bobs Wolmer's Avatar
Bad alternator,get a multi meter out and start the car and check the voltage it should 14.0-14.5 on the good side and 13.8 low side.Most parts store will check it for you for free if you can get the car there with out dieing.
wieder
Sep 10, 2010 08:42 PM
Volvolover66
Jul 31, 2010 01:37 AM
68Brick
Canada, Over Seas & Elsewhere
Jun 10, 2010 06:57 PM
pinkyjabberbox
Apr 25, 2010 08:06 PM
01S60
Mar 29, 2010 10:01 AM
