1994 Volvo 960 Wagon
Old Apr 5, 2008 | 10:08 PM
Volvo960Wagons's Avatar
Default 1994 Volvo 960 Wagon
Hello I was wondering if anyone knew how to fix tail lights on a 1994 Volvo 960 Wagon. Mine work but are very dim and also when i turn my lights on the middle light lights up and i don't think that is right. Also when my lights are on and i hit my brakes all but the middle light go completely out. I don't get it. I know it is probabally a wiring problem but i don't know how to fix it. Please let me know if any of you know anything that might help.
Old Apr 6, 2008 | 01:04 PM
billofdurham's Avatar
Default RE: 1994 Volvo 960 Wagon
Usually when lights play up like this it is a problem with the earth (ground).
Trace the black wire from the light unit to where it is attached to the frame. On the rear lights this will not be too far away, usually on the D pillar. Make sure that the contact point is good, clean and tight. Also check the contact at the light unit for the same things.
Old Apr 24, 2008 | 12:28 PM
farina43537's Avatar
It kind of sounds like you have water in the housings. Are the lights dim or is the lens getting nasty inside from the gunk that builds up in there when water sits? Do you get a bulb failure warning?
Johnny Hamm
Feb 7, 2013 09:38 AM
volvoofsocal
Aug 23, 2011 12:53 AM
volvoofsocal
Jul 21, 2011 03:58 PM
mechman1
Mar 7, 2011 04:05 PM
mechman1
Feb 7, 2011 09:10 PM
