1996 960 stalled and died. Please help
Old Dec 29, 2011 | 10:06 AM
hilde765's Avatar
Default 1996 960 stalled and died. Please help
Our 96 960 wagon has been acting-up the last couple of weeks and finally conked-out.
Starting was slow and seemed to be the battery getting weak so I was on the way to get a new one and when coming to a stop the car stalled and when I tried to restart it all I got was a rapid clicking and then the alarm system started to go crazy.
A state trooper was nice enough to try a jump but no luck. Then after sitting with the flashers on for an hour waiting for the tow truck, when I went to try again, there was absolutely nothing.
I put a new battery in and still absolutely nothing.
Any help is greatly welcomed.
Old Jan 1, 2012 | 02:28 PM
Henry10's Avatar
Assuming that new battery is good, you need to check the battery ground, and make sure it is tightened on the post, on the other end. If this is good, I open Wiring Diagrams and check maxi-fuxes.
Old Mar 31, 2012 | 06:00 AM
Nigel Adelaide's Avatar
The next thing to consider is the fuel pump assuming you have spark and the engine is turning over with the new battery .
Old Jul 18, 2012 | 01:07 PM
T77911S's Avatar
if the battery is good and you are getting clicking, i would look at the connections. CLEAN all major connections. battery to body, both ends, body to engine. check the "start" wire at the starter. make sure it is getting all the power to pull in the solenoid.
Old Jul 19, 2012 | 04:17 AM
Default Volvo 960 starting
Had similar problem and the second positive lead that attaches to the bolt on top of the terminal with aconnector had broken off and slid down by side of the battery.If our battery goes too low alarm goes crazy and have to rset it with the remote before starting againso make sure alarm is deactivated.
Old Jul 19, 2012 | 06:12 AM
T77911S's Avatar
car alarms are VERY BAD! when worked at an auto electric repair shop, they were more problems than they were worth, except to the shop that made money from them.
if you have an aftermarket car alarm, usually someone hacks into the start wire to the starter to put in a relay. i have seen very bad connections at that relay that will limit the power to the starter to pull in the solenoid.
the solenoid requires a lot of power to pull in. adding resistance (connectors), is never a good thing.
Old Aug 8, 2012 | 01:50 PM
97volvo960's Avatar
fuel pump. happened to mine 97 @ 137K miles
Old Aug 10, 2012 | 10:23 AM
T77911S's Avatar
a FP does not keep it from turning over.
bryan.pedigo
Sep 30, 2013 09:32 PM
dadsv70
Oct 13, 2011 03:26 PM
mary hada
Aug 22, 2010 02:31 PM
96960Chris
Jun 25, 2010 03:43 PM
Squid56
Sep 12, 2006 01:27 AM
